Lightning Supecharger, newbie!
now i mean it when i say i don't know jack crap about these cars. i've just been reading the posts and stuff for a couple of days trying to get used to the talk here.
1) does the lighting come stock with a supercharger?
2) what brand or kind is it?
3) can you install aaftermarket supercharger on it?(procharger, powerdyne)
4) would it replace the stock supercharger(if it comes stock with one) or does it go before it or something like that?
5) anyone who has does this can you please tell me more or give me a link to a good discussion?
thanks,
jeff
thanks,
jeff
Start
Here's a good place to start . . .
http://www.svtlightnings.com/faq1/faq.htm
Wayne
'01 L Coming Soon
Wayne
'01 L Coming Soon
the supercharger is a Eaton-Model 112, Generation 4, 8psi mechanical boost. I am not sure about aftermarket S/Cs, I have not heard or seen anybody use an aftermarket on these trucks. I think these superchargers are pretty good. That FAQ will help you a lot with what these trucks can do and are capable of doing
Paxton was working on a dual supercharger setup with a novi 2000 on the truck, but you really don't need it if you just want to run fast. If you want to go sick fast then you better just take out this motor and put a 351 in her. Thats what I'm debating on doing day by day. But these trucks do fly with a little bit of aftermarket parts. The bottle in the bed always helps out too!
I'm putting a Lightning Supercharged motor in my 2003 F-150 100th anniversary heritage edition - any recommendations? It looks like the tard that sold me the motor has the wrong induction system installed - he drilled holes in the mounting flange on the Eaton but there are no supports on the bottom for them... Any ideas?
I'm putting a Lightning Supercharged motor in my 2003 F-150 100th anniversary heritage edition - any recommendations? It looks like the tard that sold me the motor has the wrong inductions system installed - he drilled holes in the mounting flange on the Eaton but there are no supports on the bottom for them... Any ideas?
unfortuantly you are going to have to post some pics, but it sounds like you bought a '99-'00 eaton with a '01-'04 midplate and lower
Pictures posted below - I bought another one from a 99' that is new to replace it with, but will it fit on my 2003 engine? Is there any noticable diffeence between the 99 - 00 and 01 - 04 gear other than the way the blower fits the mid plate or can I use a 99 - 00 setup on a 2003 block?
Thanks for all the help!
Here is what I am buying to replace it... The seller says the new one is from a 99' but it should fit right? When I look at the new S/C it looks like it will fit the other mid-plate as well so maybe the S/C is for a 99???
If anyone can help I am extremely confused!!!
Some dude out in Cali named Gabriel Hatvani... total BS artist!!!
The replacement came from an eBay seller named parts4u2004 - here's a link:
http://cgi.ebay.com/ebaymotors/ws/eB...7;3AMEWNX%3AIT
So basically, I can use the complete set-up on my 2003 block so I'm good there. I'll call Stiegemeir and see if they can do anyting with it, then I'll set up the 04' induction with a Whipple on the motor that is coming out now... ...of course V 3.1 will also have JE Pistons, I beam connecting rods, etc. etc. etc...
Any difference in horsepower?
Thanks!
S
Thanks!
S
