Horn turned wimpy???
Alright, here goes. I bought my truck back in October, and the horn sounded fine. Then, at some point, the horn's tone changed and now my 5,000 lb beast has bark like a chihuahua. I thought this was just something that went wrong with my truck and that I'd have to learn to live with, but then I noticed last night that my friend's L with far less miles is now doing the same thing too (it wasn't before). He said he had heard that Ford's have a high and low horn or something like that, but he "can't back that up". Have any of you guys experienced similar testosterone loss with your horn, have you figured out what the problem was, and have you found any way to fix it? Thanks, later...
My horn went "wimpy" a couple of months ago, when I was on a job in Va. Beach. I was honking the horn when some zipperhead decided at the last second, that they needed to turn right in front of me!!! The first couple of secs, it was a beasty blast then it shifted to the "yorkshire terrier yelp". The horn was replaced under warranty, no questions asked. These horns are a fixed set (2 horns). I witnessed that it was a single piece assembly. Easy to remove/replace.
There are two horns in our trucks, a high and a low. Most likely the low went bad, leaving only the high pitch horn. Sometimes they go bad, sometimes they just lose a good connection. You can pull the assembly off and clean all the contacts and where the bracket grounds to the truck. If it's still screwed up, the dealer will replace for you.
my friends and I were out at dinner one night and we had our table next to the window. There was a group of people talking next to my truck and one descides to lean against it. I hit the panic button and boy did that guy ever get off quick. I know it was a bit immature but hey, get the hell off my truck
Way to go Leonard! Give those tax-lovin' pols hell.
Btw, I don't know if anybody else noticed but when I went to put in louder horns I found out that the stock ones were made by the same aftermarket company as the ones I was replacing them with--FIAMM(sp?).
Originally posted by Leonard Embody
I bought a set of air horns after both of my horns went out. I figured it wasn't Fords fault because I was part of the tax riot here in Nashville a couple of weeks ago. I pounded that horn for about 20 min. then it gave out.
