JDM Flip Chip Question
I would never run any L on anything less than 91 on any program. Jim (as do all the other tuners) does have quite a few programs of various performance levels. Normally the higher hp side of the chip would at least require 93 and sometimes as high as 100 depending on the chip. ASK THE TUNER
A little quick math
stock hp (according to Ford) about 370hp
the tuner gets about a 15% increase or about 55hp
the blower takes up hp that never makes it to the flywheel about 55hp see http://www.eaton.com/supercharger/M112.html
370+55+55=480hp
480hp/331 cubic inches =1.45 hp/in^3
or about 89hp/liter
That is some real hp from a street motor Feed it real gas!
A far as the battery... Each side of the chip has it's own quirks that the computer adjusts to in about 150 miles or so. If the the two programs are far different, it is best to disconnect the battery and let the computer go back to it's base tables and start learning all over. If the two programs are real close to each other, this will never be noticed. Only your tuner knows if this could be a problem or not.
Hope this helps
Andy
A little quick math
370+55+55=480hp
or about 89hp/liter
Hope this helps
Andy
Personally I would disconnect the battery before flipping. No voltage has to be better, just in case. If you install a breaker under the hood that will disconnect the battery it makes life much easier. Any stereo shop should have them. I have a battery disconnect hooked up on the back of my truck.
You can get into trouble when the closed loop fuel curves are different on the two sides of the switch. If on one side, the base fuel maps are a little rich, the tables will learn this trend and lean up the mixture as required. The problem comes in when you get to the track, flip the switch and pull into line. If your high hp side of the switch is a little lean as set up buy your tuner and the computer assumes that the chip still needs this leaning out and now your truck is WAY lean and detonation sets in. If you would have driven to the track after driving a couple of days in the high hp side... the computer would have adjusted to the new base program and fed the truck the right mixture correction.
PS I think that this is all on the closed loop side of the program and with drag racing most of the driving is done at full power or in open loop mode. This is most likely more of a problem on the street when 1/2 and 3/4 power is more likely, like when climbing a hill right after fliping the switch.
Hope this helps
Andy
Hope this helps
Andy
80 woa what is up with that
I too hope that the 80 octane thing is wrong, I think the lowest I see around here is 87.
Anyway if you can't find 91 or above you could use something like the torco fuel additive, I have some and have yet to try it. I got it for the race side of my chip and haven't tried that out yet. I need to get my fuel tank down a bit and then maybe I will try it out.
their website is www.torcoracefuels.com
They were very nice when I ordered it and I think it is a real good product. I have heard great things about it. You can take 93 octane up to 104 if you want to.
Hope that helps the 80 octane thing
Paul
Paul
If you want to flip the JDM Chip from one program to the other, turn the vehicle off, remove the key, and then switch the chip -- that is really all it takes.
It will take a while for your truck to learn from the new program -- depending on the program you are running, you may want to put about two gallons of 100 octane to 1/4 tank of gas for the race progam.
Sorry, meant 90 otctane, should read my post a little closer. Thanks for the replies. I'll try Jim for his input, just a little tough getting through on the phone with the time difference. Have to get my A__ out of bed a little earlier and try him in the am.
Mark
Mark
