Spare tire and limited slip
In another life I owned a Miata with the limited slip rearend. Owners manual said if you have a flat with a rear tire, put a front tire on the back and put that space saver spare on the front.
My L's spare is a Firestone Wilderness somethingorother. It's not a space saver but it's not the same size as the F1's.
Any similar warnings for the L?
Nothing to worry about. Although the spare is a different size tire mounted on a 16" wheel the overall diameter is the same as the OEM tires. Same diameter = same rolling circumference = no problems for the limited slip diff. Now, if you change tire sizes to something with a different overall diameter then all bets are off.
