Trailer hitch removal
I just yanked mine last night and the bolts are indeed 18mm. I also took the wiring off of the hitch (it has one of those one-way white plastic inserts that holds it to the piece on the hitch) and found a hole underneath that I pushed the insert in to. I also then zip-tied the big round plug and smaller rubber plug to the the wiring that runs underneath the length of the tailgate (when viewed from under the truck).
Hope that helps,
Dan
Hope that helps,
Dan
