bumper adjustment
Loosen the two nuts behind the brace that is welded to the frame they are metric ,but a deep 7/8 socket works fine. You may have to remove the rubber sheid to get to them.Do not mess with the bolts going thru the plate into the bumper.
The nuts I am tacking about can't be seen. You have to feel for them.Look at the attachment the nuts are on the back side of that. Don't worry that it only looks like side to side .When you loosen the nuts it will go up and down alot.
Hope this helps,Johnny
