NGK Plugs
You need to update yourself on plugs. Platium plugs are advertised good for 100,000 miles. They will last least last 60-70000. Believe me you don't want to change these plugs unless you have to and read all the howto post before you do and have all the correct tools especially the 7mm socket with builtin swivel.
noelvm
I put TR 6s in when we did the last intercooler. I gapped them at .44. It runs great.
noelvm
Get a set of NKG tr 6's there great and the plugs do need to be changed before 100'000 miles(get real).I get em here at my parts store they cost under $20 for a set of 8.If you need em and can't find em,drop me a line I'll get ya set up...They have proven to be a good plug for the L's.I think my numbers speak for the plugs,
Jerry
J MAN
Jerry
J MAN
.38 gap is way too close. Gapping that close will decrease mileage. I have a maf, filter, and pulley and they run great gapped at .44 and not loss of power or mileage. Several who gapped at .40 reported lower mileage. This coil on plug system will fire these plugs fine at all rpm. I was at the track last Firday the truck ran great. I talked to a "top tuner" and he didn't recommend 38. Now I guess we need a tuner war on spark plug gap.
noelvm
I didn't say they'd last 100k I sald the were advertised for 100K but they will easy go 50-60K,
noelvm
I just installed a set of those last week. Besure you have all the nec. tools!!!! It makes it lots easier. The NKG part # is 4177. Jim @ JDM recommended a 0.42 gap so thats what I gapped them and it runs good. Cant really tell alot of difference though. I did notice when I nail it at 20 mph, it spins the rear tires where use to it would chirp them 5-6 times with the stock platinums. The gaps on the stock plugs where all over the place from .40-.45!!. The last two plugs on the drivers rear are a pain in the a$$! This is where the 7mm swivel socket is a time saver on the 3rd one back!
Blownlightning,
I agree with you on the heat range.
Noel,
I agree with you on the gap.
I think the TR6's burn too lean in the cruising range and when I have gapped my plugs down in the past my gas mileage fell off about a 1/2 mile per gallon. I have had absolutely no problem running Stock, NGK, Splitfires or Autolite 103's at factory spec. gap which is .042 - .046
Noel,
