IC Fix,door crack prevent kit,seatbelt fix
Supposed to go intomorrow for IC recall. BTW, SVT dealer service writer says Ford will overnite IC fix (BS?) NLOC says fix part is XL3Z-9424-AB Manifold kit,but search on this forum lists other part numbers--what is correct? Is fix 10 row 2001 cooler? Mine is not leaking now-- I think! Read on this forum or NLOC that O2 sensor should be replaced? Any other parts? One time bolts replaced N606500-S100? SW says my veh assm. 4/7/2000 doesn't need seat belt fix or door crack prevent kit according to OASIS. That's not what I get from this forum? QUICK RESPONSES APPRECIATED! THANKS
Hello Jake,
Just got the new kit installed on my 99 last week...bad leak just started, and lost a complete tank in one week. new Kit included O2 sensors, upper manifold, 2001 intercooler (more air ), replaced plugs (I supplied new NGK's) and perform a compression check to ensure that the motor is still OK!
It is no small job, and will probably take at least 8 hours to complete. My work sheets, are in the truck, so the time is a guess. The truck feels stronger, but haven't run with ET's and chip yet....Friday
Ford will send a recall notice to al 99/00 owners soon....look for it in the mail! My leak was just timed, so I got the kit, but not the recall
...Dwight...
...Dwight...
