T5 Tranny in L?
T5 Tranny in L?
Hey guys, I tried looking for a search on this topic, but had no results (For all you search police.) I was always under the impression that T5 tranny's were used in tow trucks (so the caption says in summit.) And majority of the people say Ford cannot make or use a tranny that handle our torque ratings. So wouldn't it make sense for ford to use the T5? And what tranny's do racers use that have more than 450-500lbs of torque?!
Just a question, so please don't start attacking me!!
-Ian
-Ian
Actually a Tremec does have a limit to the torque it can handle. A Mustang T5 would EXPLODE with the torque the Lightnings have.
You may want to look into Ford's new 6-speed that they offer for the PowerStroke Diesels. Those trucks have 500lbs of Torque. Plus a 6-speed sure would make it easier to put MONSTER gears!
depends on the driver! the stick will have better gear ratios so you can get up and move faster! 5 vs 4 speeds there. The 5 will have a lower first and second gear.
The T5 in the cobras are only rated to 310 ft-lbs of torque. That is the world class unit. You can get them rebuilt to hold 335ft-lbs, but that is it.
What you want is the T56 Viper unit. Rated at up to 440-550 ft-lbs of torque! It is a 6 speed unit. There would be a lot of fab work to get it in, plus a custom shifter, but it would rock! I know that D&D performance has them if you are interested.
http://www.ddperformance.com/index2.htm
The T-5 wouldn't last 2 speed shifts behind the Lightning motor. As mentioned, they are rated a 310 lbs of torque. Lightnings are making over 440 lbs.
The first time you hooked the thing up, the T-5 would spill it's guts on the roadway in rather spectacular fasion. You would need a Viper trans.
That is the funniest thing I have read in a while. the t-5,t-45,t-3650 all have one thing in common there all P.O.S. Get atleast a D&D blue printed tranny. I would try the viper tranny, would be cool to have.
Sorry about the remark at the top but they are.
