Going to change plugs this weekend what tools do i need?
Im changing my plugs this weekend and before i start can you guys tell me what tools im going to need to do the job right. Im changing them because I found out one was loose, so i will be changeing all of them. Im going with the TR6 plugs. Any help would be great
Everything in your tool box plus at least two trips to Sears. It is a pain in the butt. I guess the secrete tool to have is a 7mm swivel socket. I didn't have one but can see where you would want it.
The worst plug to do is on the drivers side second from the rear. Fuel regulator right above it. Very limited access. Also a long handled 7mm open end wrench helps.
Bandaids for the hands too.
If possible start the job first thing in the morning before driving or starting the truck. Everything being cold will help.
