Anyone disconnect front sway bar?
I also disagree. For the last year and a half or so I have been driving around with no front sway bar. And here within the last week I reistalled it, and man...what a difference, handles much better.
For track use, I highly recommend removing it. It's not that much of a pain in the ***, but it could be tough for some because it requires getting under the truck. But you will be rewarded with better 60'.
Dont get me wrong, the truck will handle fine enough to get by, but you cant really get into the corners that quick without it, you'll notice the truck will lean more in the corners. IMO
I took my front sway bar off my 01 and it drove about the same on the street except I did notice it leaning more in the corners only. I took it to 2 different tracks and on my truck i saw no improvement on 60ft. times at either track.I put my sway bar back on and went with a different wheel/tire setup and now running better 60ft. times than before.
Ooooo... and I wouldn't drive aggressively at all on sweepers, freeway onramps, offramps... if you ever have to hit your brakes hard (cuz of slow traffic or whatever)... with no front sway bar, the rears gonna come around on you real sudden-like. It only has to happen once.
Unless someone has done testing for the above ... if so, please advise.
