Breaking in the motor!!!
I bought the truck on 10/2 and have put 182 miles on it so far. I bought with 18 miles on it so total is ~200. I have only gone like 3/4 throttle to make sure it will make boost and let it kick down a bit but i have not let it hang out yet.
I was thinking around 500 miles or so, but that could take nearly a month and i am chompin at the bit to stomp on it.
any thought on this.
Bob
Pulley and chip @ 1k miles
Bob
go for it
Hey Bob, congrats on the new L. I know how you feel, I have always tried to break in my new cars and trucks the same way that i am going to drive it. I do think that it is a good idea not to drive a new one at a constant speed. If you travel very far try and use the highways instead of the interstate. I don't think it hurt mine one bit to get on it every now and then just don't hold it down for long periods of time and don't hit wide open and let off all of a sudden, just eas up on. It will take you a good while to really get the L broke in anywhere from 5k to 7k most likely. The L seems to come alive then and you can tell by the way the tires scream. Give it a few more miles if it makes you feel better. I had to give my a twist or two right away and its doing just fine.
lets see bob, 2 days later i had a chip and a pulley and make quite a few wot runs up to say ohhhh, 110 or so ,lol.
i've always heard you should break em in like you drive em, like said above, some hard runs will help seat the rings and such, again mentioned above.
Now, go beat the Pi$$ out of it
Just Hammer on it!
I bought mine on 10/01. In the 1st 140 miles I had a few passes on it at the track. Now it has a pulley , electric fan , chip and still at 400 miles. Half of the miles were put on while going to and from track. With just a few trips to the track it has arlready run 13.00 @105. When I get the other parts on her that were on my 99, I could see some 12.50s in this cooler weather.Cheers!
Josh
Josh
