Blower/Underdrive Pulley... Alternator
I'm very familiar with pulling blower pullies as my GTP has an Eaton M90. I suspect I could Pull the one off the M112 very easily.
Why would I not do that and instead install an underdrive pulley. Wouldn't changing the underdrive pulley cause waterpump/alternator mishaps? I read about the "power/amp" package, but haven't seen anything on Gen II.
Ok
Start again. There are 2 separate belts. One for Blower one for everything else.
I have not heard of anyone changing any accessory pullies. ( the pullies for everything else )
MANY people have used either UPPER or Lower Blower pullies of different sizes. Some have changed both.
When changing the upper for a smaller pulley or the lower for a larger pulley in BOTH cases the blower spins faster so in your terms they would be OVER drive pullies.
The lower blower pulley is attached to the crank. It does NOT affect the accessories.
Does this help ?
Doug
Does this help ?
Doug
AHHHHH, there's the information I needed. The lower pulley is not the crank, but attached to the crank. On my GTP you'd have to change the crank to change the lower pulley for the blower, which would affect all accessories. Ford's RULE! Can't wait to get back into one. Used to own an SHO.
Does anybody out there use the DUB from southfloridapulleyhq.com? I had one for my GTP. Very nice.
Originally posted by LightningTuner
This question was asked not long ago. You can't use an underdrive set for the accy belt. The reason for this is becuase you would have to change the factory balancer/crank pulley and if you did that, you couldn't attach the blower pulley back onto it, stock or aftermarket.
Thanks!
BfB
BfB, the reason is because in order to have effective underdrive, you'd need a smaller crank pulley setup. And if you made it smaller, the blower crank pulley isn't going to fit onto it. Also, when you get an underdrive set for a 4.6/5.4, the new crank pulley is also a new balancer, and I don't see anyone spending the money to make something special for the Lightning because of the low production numbers.
I have something in development on under drive pulleys. The Lightning engines are internally balanced. I got the go ahead from my contacts at SVT. The stock crank pulley is a dampner. It is not for counter balance.
Same for the Cobra. You can get under drive pulley's for them. I have the water pump pulley and alternator done. I just got the measurements of Johnny's 4# pulley. Can you say one piece DUAL, CRANK PULLEY!! I'm not going to dispute the crank pulley balance with people. Some will disagree. Look at it. It is a dampner for NVH. I will post pic's when done.
