My resevior on my 01 came kinda low when i bought it, its at the bottom mark for the fill, should I leave it there or put more in or what, does it matter?
It is a closed system with no vent. That means if the cap is tight NO fluid should be lost. You will know if you have a leak, once it starts you will see a steady decline
I'd fill it partway with Redline's Water Wetter and then the rest of the way with water. At the 'full' line, mark it with a 'Sharpie" for easy leak recognition.
