blower pulley cage
topsy:
Yes, it does provide support--there is controversy as to whether it's needed. I'm running a pulley without the cage--so far, so good.
The OEM pulley is connected with one large bolt(into the crank) while my JL pulley is connected with three allen bolts(and lock washers). Btw, my OEM bolt was a b**** to break loose!
Not sure how far away you are or whether you're interested in drag racin', but each Fri nite(6pm-11pm) up to Thanksgiving, there is test-n-tune(1/4 mile strip) at Silver Dollor Raceway one mile west of Reynolds, GA--just off of Hwy 96. $20 to run as much as you want to or $5 just to watch. This Fri, temps should be in the 40s to 50s.....wahoooo! Ran a 12.882et last Fri in 58 degree weather.
Come on down and have fun.(Call me at work at 1-800-926-2136 if you have questions.)
Dan
Dan
JDM sells a lower pulley that uses the cage: http://www.svtperformance.com/forums/index.php
