Is there actually a TSB for the taillight moisture problem or just warranty replacmnt
Doesn't appear to be:
http://www.alldata.tsb.com/TSB/20/012068DI.html
Bulletins for 2001 Ford Truck F 150 2WD Lightning V8-330 5.4L SOHC SC VIN 3 SFI
Service Bulletins
TSB Number Issue Date TSB Title 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set
01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers
01-6-2 APR 01 PATS System - Diagnostic Service Tips
01-4-7 MAR 01 Engine - Oil Recommendations/Applications
01-2-5 FEB 01 Seat Belts - Warning System Operation
00-23-10 NOV 00 A/T - In Line Fluid Filter Kit
00-22-2 OCT 00 Steering - Correct Placement of P/S Pump Bolt/Washer
00-16-1 AUG 00 A/T - ``Prior To Repair'' Tag Procedure Notice
Service Bulletins
I had mine replaced several times before i gave up and fixed the problem myself. I just removed the taillights and patched all of the openings inside of the fender with Duct Tape (i know it doesn't sound good). I put the tape on the inside of the recess for the tail light. It takes several pieces and you have to overlap them to get a good seal. This prevents water from directly spraying off of the tires onto the back of the tail light through the openings in the fender and I have not had any moisture in them for over a year of heavy Florida rains and puddles. Once you put the tail lights back in you don't see any of the tape!! I know this is a low tech solution but it works.
