3lb pulley on a stock non-chipped L??
No doubt Call the man, if your wanting a JL pulley just ask him. He will tell you straight up if you need a chip. If you just wanted to try the pulley thing with no chip reset your boost actuator to the stock setting and put the pulley on then adjust you boost act back up if things are running good. You should be able to lower the boost a pound to a pound and a half just to start with. Listen for detonation and see how it feels.
I've got a track event coming up next weekend and I presently have my chip sent back to IBM (@ LIGHTNINROD) for a reburn to the latest and greatest. It should beback mid next week, I was just wondering if I should just hold off on puttting my JL 3lb pulley on the truck UNTIL I get it back.
Using the boost actuator to cut boost, hadn't thought of that.
Wait a minute! I thought you wanted to run at the trac/event with just the pulley, now you're sayin' "everyday driving". Normal, non-WOT drivin' should be fine without the chip reburn(IMHO) I know, just drive your Geo Metro until you get 'fixed'.
Bein' sarcastic and I'm tryin' to get you into the 12s.......that's not right(kevin Meany, forgive me.)
Dan
Dan
