Track results ---modded box vs 12" conical
Was able to get one run on each. After I saw my conical results I went back to the modded stock box. Each of the testing runs were made with the L at the same engine temp. The ambient temp and track stayed the same. Everyone has there own conclusions to what they like. My modded K&N filtered 01 box has a 4" hose in the bottom of the plenum that goes to a 6"x4" pickup just under the bumper. I posted pictures awhile back so they are out there. Here are my numbers...
modded stock.........12" conical
60' 1.86......................1.85
1/8 8.120...................8.182
mph 85.56..................85.05
1/4 12.72..................12.81
mph 106.19................105.63
Another Beliver
Jeff,
My point exactly,i have done this very same test several different times with the stock K/N modded airbox always outperforming at least 1 tenth faster every time! People want to draw there own conclusions on this and usually ends in a standoff debate which i will not get involved in anymore.I know 2 guys that were big belivers in the open filter until i convinced them to try my way at the track and both now are running the same setup as me!
Matt
Matt
LOL...................
Originally posted by CornerCarver
HR,
Got any pics? I'm probably gonna do the same thing since I've got a panel filter coming. I "rigged" a 6" cone filter and I would really like to clean up the engine compartment.
HR,
(Sorry, Paul, it was just too tempting!)
Dan
JeffsLightning - hey I just did my airbox mod similar to yours this weekend, except I used 2 1/2" hoses going into the stock airbox w/ a K&N. Anyway have you had an engine light pop on since you did that mod?
I did mine last night and drove around, then it rained on the way home. So I got home and checked everything out, no water in the airbox and no leaves or any debris in there after about 20 miles of driving. Well going to work this morning my engine stalls at a light and I get a check engine light, but when you do the test with the mileage gauge no error codes pop-up. PITA!
Re: Track results ---modded box vs 12" conical
Also, I gained .1somethinganother at the track by taking my K&N filter out all the way and just running through the stock airbox. This was in cool weather (50ish to 60ish, though). Ivan (usahooters) did as well.
Remember, on the dyno I barely gained anything comparing filters. Proof in point, as always said, that there isn't enough airflow on the dyno to take advantage of intake mods. Here's the link again w/ the comparo on the dyno:
https://www.f150online.com/forums/sh...ighlight=worth
BfB
No captain I have not had any service engine soon (SES) lights. It might just be a quirk. I would reset the pcm and see if it comes back. One thing that I do though is since I used a 6"x4" pickup under the front bumper a plastic coffee can lid fits perfectly over the 6" hole. This way whenever there is bad weather i.e. rain or snow I can put the cover on the inlet easy enough. hope this helps...Jeff
Re: Re: Track results ---modded box vs 12" conical
Originally posted by BfB
Jeff, which dealer's 12" conical filter you were using? Does this filter setup replace the stock tubing in anyway, and is there a shield?
