bulb # for fog lights
Hello everyone,
I am looking for for some superwhites with a slight hint of blue for a pair of 99 Lighting fog lights. Do any of you have any already installed? and if so can I give me the info on where you got them and how much? Pictures would be great as well. Also, how about superwhites for the corner lenses? Thanks.
Robert
Robert
What's your bulb number?
Mine was a #9145 bulb, and i purchased a set of Xenon Blue Brights from JCWhitney for 9.99 onsale. Model #9005 on the advice from someone on the boards. Bulb didn't line up perfect, but went in after a minute of fidgeting. They work great at lighting up a broad path in front of me.
Why couldn't ford make the headlights easier to adjust? Does everyone have to remove the whole headlamp assembly to adjust and then reinstall over and over or is there a simpler way? I can fit the 1/4" rachet and socket on the adjuster with them installed. But foglights worked great none the less.
