Need help quickly!!!!
I have my truck jacked up right now and I am underneath looking for a way to run the ram air through the fog light holes. Looking behind the bumper, it looks that it will be pretty easy but I just need to know about one thing. Behind the bumper, there is a peice of metal (from the frame that holds the bumper on) that extends over the back of the fog light. It looks to me that I can cut out most of the bumper it self and just bend the metal paice of the frame back and then use a peice of hose clamp to hold some dryer hose to the fog light assembly. By bending the frame back, I am thinking that if I ever wanted to put the fog light back in, I could just bend the peice of frame back to the way it was and put bold the fog light right to that. Does anyone forsee a problem in doing this???? Will it still be adaptable for the fog light????
I just went out to home depot and bought 60$ worth of crap and by looking at my plan again, using the passenger side fog light probably wont produce enough air to be worth it because the air would have to shoot straight across. What I will probably do is run the drivers side as a ram air and the passengers side to the sc. Any better ideas???
I currently have a stull grill installed and would like to get custom round ones made for the hole.
Well, I got the drivers side fog light hooked up last night and took her down to the local street races. What a difference it made. Instead of kinda loosing accelaration after 2nd gear, she went very strong even through 3rd. Definatly noticable difference on top end and the power increase felt about 2x greater than my prior JL ram air kit.
