cxn1 processor in 2000 L
do you think i could use a cxn1 processor in my truck i have a 90 mm mass air other than rear gear is their any other thing that would stop me from using this computer like more or different sensors and/or all the pins the same???????
sal, jl, anybody have a response
p.s. i didn't fry my processor i only said that because i thought i did, and i am still thinking about changing processors
Hi RDY2RAC,
You'll need to deal with the PATS system when you replace the ECU in most 1999 & up F-150's, and either have your existing keys reprogrammed for, or a new set programmed to the new ECU. That aside, operationally you're lucky in that the Lightning has only had 1 ECU revision each model year, and no major mechanical reconfiguration.
Assuming you have the factory 90mm MAF from the 2001 Lightning, your A/F's should be OK, but it would be a good idea to check & make sure.
Make sure to shop, as Ford ECU pricing varys quite a bit from one dealer or source to the next.
Good luck!
Good luck!
Well someone please correct me if I'm wrong, but my understnding is there are NO PROGRAMS, new or otherwise. only tables that continue to be refined, and second there are more tables to define on 99 & 00s than there are on 01s.
noelvm
A table is like a 10 by 10 grid with 100 possible entries. All 100 entires are changeable and any entry which you change will make a difference, either good or bad. It is the constant refinement of these tables, thru trial and error, that are being changed. There are no programs.
noelvm
