Power
Power
Hey i need some help from all of you that installed stereo systems in your L's. Where through the fire wall did u run your power cable from the battery? The only way i can see to do it is through a drilled hole beside the battery. any preexistin g holes i am not seeing that would make this alot easier? Thanks
merry christmas
merry christmas
check this thread: https://www.f150online.com/forums/sh...threadid=60091
run your wires behind the battery, on top of the inner fender, then up thru the grommet under the passenger side door sill.
remember to use a fuse!
more pics in f150online gallery..
