Removed Old Throttle Body (yuk)
The breather cap will definitely help!!!!!!! Mine wasn't as bad as the pictures of yours but the back pressure when you let up on the throttle will blow oil into the throttle body.You may even want to do both sides the cap on one and a small piece of hose on the other side with a small K&n filter,that should eliminate all of the blow by....
Good luck
Jerry
Good luck
Jerry
