Cobra-R motor
If you were able to pick one up for cheap (how im not quite sure), it would be better to put a Procharger F4 on it or a Turbonetics T66 Turbo on it. A roots blower would not be the way to go with that beast.
As for the internals im not sure what they are. But I am almost certian that you cant run to much boost in the motor due to the raised compression.
I'll have to go back and read up but I believe the internals are all aftermarket pieces. About the ? of supercharging or turbocharging it, I would definately turbocharge it. That T66 would work great, its a nice all around turbo. If you want to get crazy then you could go much bigger but it would suck for street driving. I believe the T66 can handle up to high 600hp anyway.
Hey Bolt, Found this on mustangworld.com
2000 Cobra R
Stats
ENGINE
Configuration: Longitudinally mounted, 90-degree V8: cast-iron block: aluminum heads: forged steel crankshaft: billet steel connecting rods: forged aluminum pistons; McLeod aluminum flywheel
Bore x Stroke: 90.2mm x 105.8mm
Displacement: 5,409cc I 330cid
Compression ratio: 9.60:1
Horsepower: 385 bhp @ 5700 rpm (estimated)
Torque: 385 lb-ft. @ 4500 rpm
Redline: 6500 rpm (6.800 rpm fuel shut-off: 7000 rpm ignition cut-off)
Valvetrain: Double overhead camshafts: chain drive to exhaust cams, secondary chains from exhaust to intake cams: roller finger followers with hydraulic lash adjustment: ovate-wire, beehive-shaped valve springs: four valves per cylinder
Intake valves: 2 per cylinder, 37mm head diameter
Exhaust valves: 2 per cylinder, 32mm head diameter
Ignition system: Distributorless coil-on-plug
Fuel system: Sequential electronic fuel injection
Intake manifold: Cast aluminum, tuned equal-length runners
Throttle body: Single oval bore
Mass-air sensor: 80mm
Air filter: K&N cylindrical
Exhaust manifolds: Stainless steel short-tube headers
Exhaust system: Bassani X-pipe: production 98 Cobra catalysts: Borla mufflers and side-exit exhausts
Ron
2000 Cobra R
Stats
ENGINE
Ron
