Denso Vs NGK
Denso Vs NGK
Ok, i have had people tell me, run Denso, run NGK, and i noticed different tuners advocate different plugs. I also have heard from a 300ZX TT owner that denso's run hot, causing detonation? What are you guys' experiences? I am leaning toward the denso's. What can I expect with the new plugs? For mods i only have an air kit, and chip, but i am adding ram air and a 3lb pulley soon.
(When I say Denso, i mean the Denso Iridium (IT20's?) and the NGK TR5's)
00FireRide,
Good luck on getting a definitive answer on this one. I posted a pic of a TR5 to compare to a Denso but after repeated requests nobody would take a pic of the Denso to post.
The TR5 runs and idles great in my motor. The burn is good too. Here is an updated pic of them at WOT and daily driving. The WOT pic is #5 which is usually the leanest cylinder in most L's.
If you like what you see go to carquest and get a set. They usually have them on the shelf.
When I get mine in, I'll be happy to provide a pic or two. I'll run them a while first though. I don't mind saving the next guy a buck or two if they aren't worth it. For 4#s of boost on a dayly driver, either plug should be fine. The densos are the only plugs I've heard of to actually make power though.
I have been running tr6's for a couple of months now. I do run a 4" vacume/boost at all times. What I have noticed is that during warmup and general traffic driving to work, the vacume runs about 18 inchs once the truck warms up. The idle will have a slight miss. Once I get on it the first time, the vacume goes up to 18 1/2 or 19 implying that the plugs may be a little cold to deal with extended idle and warmup. I do like the added insurance for detonation.
Andy
Andy
The price will prob. make up my mind. 1.99 per NGK TR5 (i think this is the one I use (compared to TR6, since I have an air kit, ram air, and a chip - also soon to be 3lb pulley), compared to an 11.99 Denso. That's 10 bucks more a plug!
Full Set of NGK TR5's = $16.00!
Full Set of Denso IT20's = $96.00!
They can't be worth 80 bucks more than the NGK plug. ALSO, When I go to new performance plugs, what is the perf. difference in the truck? Better throttle response?
Here's that quote from MRBBQMAN.
P.S. Thanks FlashSVT. I have more to add but it's hard to find the time.
new or broken in? i just installed denso's to see how they hold up to the squeeze compared to the splits. the initial "feel" is like falling off a cliff. i wouldn't be suprised if a new set of splits would dyno more hp than a new set of denso's
Here's another issue with not just conflicting opinions, but conflicting data as well. If the search function was working, you could find posts that claim better e/ts and an increase on the dyno. Throttle response improvement is another reported benefit. I should know by the end of the day.
I ran the stock plugs with 3lbs of boost thru 18,500 miles with no problems and a 12.791@106.59 1/4 mile.
When I went to a 5lber, I feared a too 'hot' plug so out with the old--in with the NGK BR7EFs(.040 gap). Man, I hope they're the 'right' ones for my L--I shudder at having to go thru 'that' again anytime soon. Mine is a daily driver too--'cold' plugs and a 160* 'stat may turn out to be too 'cold' to keep from fouling but, so-far, so-good. I've put about 1,000 miles on them and it runs clean--will pull #5(thanks Chuck) Sat and look at it under my 'glass'.
I've got about 2500 miles on my BR7EF's, and have not fouled them out yet. That does include lots of low speed stuff here on the LA freeways.
they ren well at the track when I first installed them. The TR6's showed signs of erosion, with the tips definitely getting hot.
Here's a look through my plug magnifier.
