Valve body install?
I wouldn't even pay someone to do it. It's simple. Plus the money you save for labor you could put towards any needed tools, plus the 4x4 tranny pan and filter.
Jack up the truck enough to get in.
If your replacing the tranny pan, just punch a hole in the older one to drain most of fluid.
Remove old pain.
Carefully remove filter b/c it has alot of fluid in it.
Swap line mod valves.
Replace everything.
Fill with fluid.
Clean mess.
Wash hands with orange soap.
Should take only 45-60 min,
Remove old pain.
Replace everything.
Fill with fluid.
Clean mess.
Odin,
Do it yourself. I'm an average wrench turner that knows his limits and will be swapping the valve body. Simple drain, unbolt, remove, replace with new, button it up, and refill
The only special tool required (and can rent) is an IN/LBS torque wrench. Otherwise a floorjack, a set of good jackstands, and decent socket set.
Or, you can drive to Indy and pay me $155 to do it for ya...
Bob
Bob
The problem here guys, is not whether I can do it myself or not. It seems easy enough. Torque wrenches and I do not get along at all. Any time I do anything involving a torque wrench, it ends up costing me money, time, and probably a few years off my life, too. I'd rather pay a pro than take a chance on this one. Jeeez, this is embarrassing.:o
Roger
Roger
mbrown,
That's real nice of you; but, NozeBleedSpeed has called me out. Now I have to do it myself. I will, however, be posting about something that shouldn't have happened, but did anyway, in the next few days. I have a 6th sense about these things. I got the B&M pan to go on in place of the original, also. Thanks for the offer!
Roger
Roger
