Reimburesment for intercooler?
Hello,
I wouldn't do the work yourself.
There are other procedures they do while they are in there that you might not know about (or have the ability to do).
One such thing I know of is that they have to re-flash your computer with the correct calibration for the intercooler change.
They also check the emission system, the plugs, the supercharger, etc.
Bottom line. . .you want the dealer to do it.
The good part is that you will get a noticable power increase, and you know that if something is messed up or effected in some way by the swap, that you can have the dealer make it right.
Good luck!
Good luck!
Ford will not pay to install parts that are not OEM for the truck. The only time a recall will reimburse is if you paid to have the work done before the recall was issued. That means you paid to have the same exact work done.
BTW, give me a call, I have some info for you on the motor stuff.
Originally posted by Silver_2000_!
This is the first i have heard of a computer reflash for intercooler swap... If thats the case then if they updated the cux1 to a cux2 then my chip wouldnt work... Im pretty damn sure they didnt flash my computer...
Doug
Doug
Mine was reflashed when the intercooler was changed.
They told me that sometimes they have to, sometimes they don't, it depends on the vehicles calibration code.
My box # is CUX1.
Cal. numbers before the swap: XL3F-905172-AGB
Cal. numbers after the swap: XL3F-12A650-AGC
That's what the sticker the dealer put under my hood says.
I do know that they told me they needed to do it because after the swap my truck kept popping trouble codes. After they reflashed it, all was well.
I don't know if every truck requires a reflash or only the early '99s like mine. Perhaps the tuner-types can shed some light?
Later,
My box # is CUX1.
Later,
