bulb help
bulb help
Im a pretty good mechanic but for some reasom I having a little trouble extrcaton the headltembulbs.. Any tips guys.
What is the actual bulb number in the 01 and is there a better replacement such as a 55/100W
and a better beam pattern without changing the whole asqembly? thanks anyone.
Not sure what you are asking. If you are trying to get the headligh bulbs out, there are two clips under the hood over each lens piece. Lift them straight up and the whole assembly comes out for easy replacement. As to which bulbs to use, I am still trying to find something that will not just put out more light, but will have an unusual look to it, i.e. blue glow without going to the very expensive HID.
I think there is a good section on bulbs and links in the FAQ section of this forum.
Good Luck
Good Luck
