Replacing the PCM
Replacing the PCM
I know that if you were to install another PCM into our trucks that it has to be programmed for the PATS system. What is that exactly and what is actually input into the PCM (ie VIN number or odometer readings)? The reason I ask is, if and when the L goes back into the dealer for warranty work, can I just swap out PCM's? I changed the PCM in my '98 Ram for a Mopar Performance PCM and had to have the dealer input VIN numbers and odometer readings, so I hope that with the L's it is a plug and play type of deal.
So does anybody know...Sal...JL???
Thanks,
Doug
Thanks,
Doug
