Is it possible to change PCM to save warranty
I have heard some talk on the board that you an get a new pcm with the coating on the contacts that you use to replace the one with the chip worn contacts when you take the truck in for service.
Has anybody actually done this, does it work, what is the procedure as far as getting it to match your keys and how much does it cost.
I guess only the dealer can do the pcm to keys matchup, is this something a dealer will do without geting suspicious, can you just go in with your keys, order one and walk out with it ready to go in the truck.
