What Pressure Are You Running Your F1's @ The Track
I've found that it really doesn't make much difference here on the So Cal tracks. They are all pretty slippery. I ran around 27-28 lbs. most of the time. Some guys say you will get better traction if you switch from side to side at the rear, too! I found I got better traction if I switched to ET Streets. They instantly dropped .2 off of my 60' times.
Good luck.
I always run my fronts at 44 lbs. at the track.
Good luck.
