stock spark plugs
all spark plugs have a "boost life". if you spend a lot of time in low boost 0-5psi, your stock plugs will last a long time. if you spend a lot of time in hi-boost (6-10) your plugs will last about 1/4 of that low boost time. the stock platinum plugs will last a very long time in low boost conditions. in hi boost the plugs are a "comsumable" and need your periodic attention, or something
Will i gain anything by changing to one of these high quality plugs???? The ones mentioned above? In other words is the money being spent worth it???
FlashSVT: are those the same as on the PSP website???? Why are they some damn expensive there then??(unless they include shipping at its all 8 for that price)
Listen to MRBBQMAN. He speaks the truth--about boost life--not too sure about some of the other things he has said . I changed mine at 18,000 miles and the platinum 'pad' under the ground electrode was worn away on most of the old plugs. I've been useing extra boost for 15,000 mile or so.
I got my NGKs from PSP and they were only about $20.00--for eight plugs.
Dan
