fog light replacement
Both of my fog lights are cracked. One of them is severely cracked in several places making it easily visible when standing in the front of the truck. So I was actually thinking of replacing them. Is it suggested to replace them with the same ford type. Or is there another (better) brand to use? Hopefully something that is more durable, accommodating for higher wattage bulbs, and looks good as a replacement.
All suggestions welcomed.
I use the Hella lamps that Summit sells for $36 or so a pair.
(The ones for the 87-93 Mustang GT)
The wiring connector that comes on them MAY be diffrent than the one on your L, but simply put your wires on the new assembly if that's the case. The wires are connected to the light bulb the same way.
I've gone through about THREE sets myself now in the year that I've had this truck.
Later,
Later,
Originally posted by Marc Carpenter
Your dealer shoud replace them. That is standard practice.
Warranty item.
Warranty item.
FOG LIGHTS
If they don't warranty them I have a set of new fog lights that will fit a 1999-2000 with bulbs took them off my 2000 L when I replaced them with a 2002 bumper and fog lights!! Drop me an e-mail make me an offer and pay for shipping. There are still in good condition they were replaced by Ford about a month in a half ago. Barley ever used no breaks in glass. Just wanted the new style.
Front Lamps, Fog Lamps, Fog Lamp Assy, W/O Bracket(R) $94.58 $73.78
Front Lamps, Fog Lamps, Fog Lamp Assy, W/O Bracket(L) $94.58 $73.78
This is the price from Ford..
E-MAIL ME - RA6870@MSN.COM
I haven't been using mine for this very reason. I figure it must be due to the differences in internal heat and outside temp. I'm trying to locate some 9145s with ~35W bulbs, even though they will be less effective. I figure less heat will prolong their life. If I can't find any bulbs, I'll be replacing the lights with some aftermarket driving lamps.
I wonder if the cracking is being accelerated by an environmental stress crack agent. I assume the lenses are polycarbonate. If so, then brake fluid, gasoline, acetone, strong bases, and many other organic fluids would GREATLY accelerate their tendency to crack.
esche,
I bought my '01 L at Covert in Austin. One of mine cracked about a week after I bought it. Same story. They wanted to take a digital photo and send it to the factory for evaluation. It wasn't the heat because I hadn't even turned them on. Now the other is starting to crack too. They have a problem with the fog light lens and won't admit it. BS
Silver '01
DOB - 03/09/01
Bed Rug, Snug Top
K&N Filter
Infinity's, MTX Thunderform
Hyfonics Z700 Amp
Silver '01
DOB - 03/09/01
Bed Rug, Snug Top
K&N Filter
Hyfonics Z700 Amp
4apc.net!
99Red-
Tried that site.... it's a computer company site....!
So, I tried 4apc.net.... that one worked!!!
Here's a link to the 4.5 "DRIVING" light...
http://www.4apc.net/home.htm
Anyone try these yet?
Thanx for the info!!!
