How do 295/40/20 ride?
Some of my buddy's were talking about the 20's that I want to get. All of them said that the ride would be bad. Because of the thickness of the 295/40/20 tire. I was thinking of the BFG g-Force T/A KDW or Dunlop SP Sport 9000's. Does anyone know how the ride is on the size and brand of tires? I have to admit that I know nothing about automotive things. So I am very gullable in this sort of thing. So if you can help me out that would be great.
Thanks,
Wheeler
Thanks,
Wheeler
Re: How do 295/40/20 ride?
Thanks,
Wheeler
Thanks,
Wheeler
One word of caution however. A thinner sidewall also means there's less (sidewall) compression area available to absorb the road impacts when you hit a bump or pothole...so keep that in mind so you don't damage a wheel. This is normally what causes people to say you will get a rougher ride--less sidewall flex which acts like an extra shock.
If you want to determine exactly how much sidewall difference there is for any tire on the market, goto http://www.tirerack.com/tires/tiretech/general/size.htm Which will walk you thru it. Hope this helps.
I have 295-40-20 Goodyear HPZR tires they are ok, great handling. I like profile and the looks and stance it gives my L. with the lowering kit. Stance is everything when my L. is parked it looks fast!!! I guess the taller the tire the ride will be smoother because, there will be more cushion.
djy
djy
