Help me understand
Originally posted by Boostin01L
What I'm trying to say is most dealers void your warranty anyways so why wait?
From the SEMA site: "Unless the dealer can prove that the part that failed did so as a direct result of a part you installed, he is obligated to fix it under warranty. " (end excerpt)
If you overboost, and destroy your motor, yes, it's on you. But they can't simply void your *entire* warranty because you have a chip, as much as a lot of dealers would like you to believe.
Here's a good resource if you've been given grief by a dealer over mods: http://www.enjoythedrive.com/content/?id=8124
One final note - you'd be amazed at how fast a dealer will change their tune when you turn up the heat on them.
