Cleaning exhaust tips
Has anyone ever raised the height of the stock tips? Mine seems to hang kind of low, thus it picks up more junk from the road. I tried raising it this past weekend, but in order to do so, the hanger that is bolted to the frame needs bent upwards about three inches. If I could eliminate the rubber hanger and just hard mount the two hangers together, that would be ideal. I got brand new exhaust tips a month ago from Ford (replaced under warranty because they looked so bad), and it has been quite a chore to keep them nice. I get a pitted area (looks like it was sand blasted) on the forward most tip from the bottom to about halfway up. If the Exhaust was raised up higher, I believe that this problem could be eliminated. Anyone else??
OK-
When I first heard about Ceramabryte, I ran right out and bought a quart bottle of the stuff. Turns out that after ONE use, it dulled and scuffed my tips to the point that I almost couldn't bring them back. I don't recommend using that kind of agent to clean the stock tips. Ceramabryte is not intended to clean ceramic. Or metallized ceramic for that matter. It is intended for use on glass, or stainless steel (like restaurant sinks and the like).
I wanna put this topic to bed right now. . .If you have stock tips, DON'T USE CERAMABRYTE or any other abrasive cleaner. The manufacturer will tell you the same thing (I know- I let 'em have it good after my experience!!) If you happen to have stainless steel tips, then these products are fine. But metalized ceramic (JET-HOT like the stock tips) needs to be cleaned and polished via other means. Mothers, Wenol, Gold Class metal restorer, all these are good. Steel wool, or any other abrasive methods are bad.
CrazyFoo-
You found out the hard way (just like I did) about Ceramabryte.
If you didn't grind that stuff into your tips too much or too hard, then you can bring them back.
1) Thoroughly clean them with brake parts cleaner and a terry cloth towel. Make sure they are clean and dry and in the shade when you do this.
2) Get some Mother's metal polish in the red can (not the new billet stuff). Moisten a wax applicator pad with some water, wring out the excess so that it's barely damp. Put some of the polish on it and rub it on the tips using a circular motion. Keep going until the goo starts to turn a dark black.
3) Grab a 100% terry cloth towel (clean and dry) and buff the black stuff off. I use a motion similar to a shoe-shine boy. Once most of the mothers is removed, grab a dremel or buffing wheel and hit the tips with it. If you don't have access to a buffing wheel, then use another clean towel and just buff the crap out of them.
If this technique doesn't bring them back then you will have to go the hard route and use jeweler's rouge and a high speed polisher. E-mail me if you have trouble and I can help more.
Let me know if this works for you.
