Cleaning exhaust tips
Hello,
I've posted this before, but it was a while ago.
If you want tips that look like this:
Then use Mother's polish on the outside, a buffer helps, but it's not necessary. On the inside, you can use a wire wheel (Brass or steel is OK) to get the crud off, then use Mother's on the inside as well. I used a dremel, but any brush should do the trick.
Have fun!
Have fun!
Brass wire brush on a drill for the inside followed up by Mothers, Eagle1, or Weinol metal polish on the inside and outside.
BE CAREFUL! When you get the wire brush near the edges of the tips it has the tendancy to fling either towards the ground or towards the truck! Very easy to scratch the paint! (Believe me)
