Reading and Autotap
Reading an Autotap
I have an EASE (Autotap). In an attempt to check out a problem with my truck I find an error code (DTC):
Actual Axle Torque w/Min & Max Avalable Torque Status U1262
Anyone have a clue what that means? Is there manual/info available that fully explains Fords error codes.
Here is a link to the ATap users manual. I think there are codes and explanations for them in the back.
http://www.autotap.com/files/AutoTapManual.pdf
This may help
http://www.obdii.com/dtcanatomy.html
Ford gives
U1262 - SCP Communication Bus Fault - Perform - Go to Workshop Manual Section 418-00, Network Communications Test Module Communications Network
see
http://personal.riverusers.com/~mira.../2000_HEC.html
http://www.batauto.com/Ucodes.html
Ford gives
see
I have the same code. I have a '98 F150 4x4 5.4L. I tried to have the computer reset for my correct tire size. I found out it can't be done on the '97-'98 models, but the guy and the shop did reset the octane rating up for me. I noticed the truck cranked for 3 second before starting. I was told that it is normal while the computer relearns. On the next start I got the DTC U1262 code. I've been told it is a computer interface problem, I can erase the code and start the truck and it runs fine, but once I shut it off the code come back.
