horn sounds like a ricer...
Hey...mine has done the same...crawl up under the dash and look...you should see the wiring going from the steering wheel until to the horn's general location...jiggle those around and make sure nothing is exposed...because it could be a simple short in the wire...if something is cut...electric tape it and enjoy the old school horn sound...
it was working after wash though. so broad pulled out in front of me and i blew the horn at her, then when i got out and tried to lock it, the horn sounded weak. then i drove to L.A. and back (700 miles yesterday) and still same problem. ill check the horns behind the air dam.
thanx for all the help!!
