pulley...no chip?
Old 04-09-2002 | 08:59 AM
CEB's Avatar
CEB
Question pulley...no chip?
Are any of you people or do you know of anyone that is running a pulley and no chip? If so, what kind of gains, problems or comments do you have?
Old 04-09-2002 | 09:09 AM
topsy's Avatar
You will most likely run lean under boost, and damage your engine.
Old 04-09-2002 | 09:43 AM
LIGHTNINROD's Avatar
Thumbs down In Kevin Meany's voice:
"That's not riiiiiiiiight--runnin'g around the house with a pair of scissors in your hand--you could put someone's eye out!"
Adding boost is similar to increasing the compression ratio. The PCM expects to see about 8 lbs of boost at WOT. If you add "X" lbs of boost to that, the a/f ratios and timing will be too aggressive and things may/will go 'boom'!
Dan
Old 04-09-2002 | 09:56 AM
Silver-Bolt's Avatar
I disagree. Running 1-2lbs of extra boost is not a problem. Beyond that and you should have a chip as well.
Old 04-09-2002 | 10:07 AM
CEB's Avatar
CEB
I started this topic because I'm looking for performance upgrades that are less likely to void my warranty. I definitley need a little more performance...I had a 99 trans Am and 98 C5 vette before the lightning...both 6 speeds and they both felt a little quicker as far as SOTP. I know everybody says buy a chip and get the best bang for the buck, but then I hear of people having warranty issues once they have installed a chip. Basically I want as much performance as possible with minimal warrany issues. So any advice will be appreciated.
Old 04-09-2002 | 11:27 AM
Lightningquick's Avatar
Tell jdm exactly what you told us and youll be pleasantly suprised!You dont even need a pully,Hes got a bag of Lays for you that you swallow without chewing!!
Old 04-09-2002 | 11:31 AM
DB's Avatar
DB
Originally posted by Lightningquick
I hear JDM is making just what you need!!
Its like having chip performance without a chip
Tell him exactly what you rold us and youll be pleasantly suprised!You dont even need a pully,Hes got a bag of Lays for you that you swallow without chewing!!
LOL funny stuff
Seriously, though, I think you can safely run 1-2#'s of extra boost without a chip as Silver-Bolt mentioned, since the stock programming is pretty rich to begin with.
Old 04-09-2002 | 12:10 PM
soap's Avatar
I ran a 4# lower for a month with not a peep of anything wrong at all. It was March too<<<read cold in MI. I am now running a chip because I wanted MORE POWER
--Joe
Old 04-09-2002 | 12:16 PM
kidtriton's Avatar
To a certain point , more boost means more air is brought in through the mass air meter, and more fuel will be added. I dont know at what point it will start to lean out though.
Old 04-09-2002 | 01:11 PM
HIGH ROLLER's Avatar
Cool
Everyone just assumes since we are adding a 2,4 or 6# pulley that are trucks are running way to lean without a reburn and will damage are motor but how many people actually know how much these pullies lean it out without a chip on stock computer i would say practically no one except the tuners or dyno junkies like myself that have done this many,many times.My opinion on this as far as air-fuel is concerned we are safe all the way up to a 6# pulley at least.When my truck was bone stock my air-fuel was around 11.6 and with the 2# on it jumped to 11.8 with the 4# on it was never more than 12.0 and the 6# did go up to 12.3 all with no chip and i have driven my truck during the winter months without a chip with many miles and never had detonation or any problems whatsoever!I would be alot more concerned with a 6# pulley and chip than a 6# pulley without a chip because of the added timing and higher shift points the chip gives you.There are alot of chips out there that guys are running that are alot leaner than 12.3 with the added timing and shift points with the bigger pullies!This is just my opinion on this because i see this all the time being brought up.
Old 04-09-2002 | 04:53 PM
lol
Old 04-09-2002 | 05:20 PM
Boostin01L's Avatar
You make a very intresting point HIGH ROLLER
Old 04-09-2002 | 06:19 PM
kidtriton's Avatar
plus back in the day of my 89 supercoupe we used to spin the heck out of that blower with overdrive pulleys and didnt ever have a problem. I think (from my experience as a driveability tech) that if you put a pulley on with a stock PCM, and drive it "normally" for a few days, if it weren't able to trim the fuel ratio out ( keeping under 20% long term FT, other techs will understand this) the check engine light would come on due to the creeping long term trim. If the light doesnt come on, I would assume that the fuel system was able to compensate. I'm not a tuner, just a technician, so dont hold me to this, its just my theory.
Old 04-10-2002 | 05:10 PM
Mondo1's Avatar
Highroller and Silverbullet are right .The Mass-air meter WILL compensate for added air rushing by it.Thats what it does.It will add more fuel up to a point.Those air/fuel ratios Highroller mentioned sound right.Though,I'm not convinced that the aggresive timing of an aftermarket program is a real issue.With good fuel and no detonation, you should be in the safe zone.
Old 04-10-2002 | 05:42 PM
qball2439's Avatar
Highroller is right....but wait until the MAF pegs and resets....
Quick Reply: pulley...no chip?
