Question on MAF sensor
Hey everyone,
Can someone tell me what the ford part no. is for the 01-02 90mm MAF sensor is? Also, in everybodies research; what is the largest MAF sensor out there that will work on our trucks? I know that Pro-M makes an 83mm and there is of course our 90mm. Anything else? I remember reading a thread about JDM coming out with 100mm. Anymore information on this MAF subject, I would apperciate it.
Thanks,
Chris
Thanks,
Chris
Pro-M makes bigger MAFs, I believe something over 100 if you want. They're pricey, and you probably don't need it unless you're going faster than 117 in the 1/4. The only real benefit I can think of to something like this would be if you're pegging the voltage on a 90mm... I would just stick with the Ford 90mm piece, it's quality and CHEAP, two things one rarely sees together in one package.
