Anybody have your seat replaced under waranty?
With less than 4000 miles on my truck there is a spot on the drivers side seat that is starting to wear thin and looks like crap.
If you rub your hand across it you can tell that there is a small pocket in the foam. When you get in and out of the seat, you rub across that pocket and its wearing the fabric thin there.
The dealer should replace the seat right?
Andy G
Andy G
suede is not mentioned in any of the lightning brochures i've ever seen.. what you are calling suede is "alcantara" a cloth that has a suede like texture. the black inserts in the seats and door panels are leather.
http://194.244.130.206/english/istit...le/societa.htm
I had both of my seat re-upholstered(sp?) under warranty. They didn't even think twice about it, they just said they would do it. Only problem was that since the new covers were put on by hand, it isn't quite as tight as stock. It has gotten a lot better over time and is not noticable anymore.
-Kimball
-Kimball
I had my drivers seat replaced at 6000 miles, steel brace was pushed completely through the foam cushion and caused a 6 inch wear mark on the fabric cover (also replaced). When the tech replace the foam he wrapped the steel bar in jute padding to hopefully stop it from wearing through the foam again. A month later and no problem, looks perfect.
I have an '02L and after about a few weeks you could see and feel a wear spot on the outside bottom bolster where you slide in and out of the drivers seat.. the only answer I had was Wet Okole's.. this was after I read a ton of threads.. am happy with them but agree that the seats look and feel great new but it dont last long..
dboat
dboat
Did they replace the entire seat covering or just the left side of the drivers seat? My 99L has the same problem, also I dropped a little ash on the right side of the seat, it isn't real noticeable but you can see it.If they replace the entire seat covering that would be a bonus. Wet Okole's next
I was thinking about getting the wet okole's for mine until i heard that they make your back sweat. anybody tried these ones from the ford collection http://fordcollection.com/s11002.html they come in black and tan.
