Belltech Drop problem
OK I was recently removing my hitch and Rear end links and noticed the Emergency brake was rubbing on the frame and the Spring on passenger side. Without removing the spring, is there anyway to remove the Emergency cable and run it under the spring so as to not pinch it causing premature wear?
Here are a few pics. What tool/s should I get to do this as I have never done this.
Jason
Jason
I moved mine under the spring. Also there is a metal harness that holds it in place that bolts to the top of the pumpkin. You can slide the cable thru the harness to take out some of the slack. I found that when placed under the spring, the excess cable bows out and wants to rub against the inside face ot the wheel/tire. You can take the bow out by adjusting(sliding the cable thru the metal harness) on the top of the pumpkin.
here is how i set my bracket up, nothing like the instructions, like the rest of the install
to remove the silver clips here are three arms the hold it in place i used a set of pliers and a screwdrier to push them in, when they are in, push it in and it will slide through the bracket, on the pass side u dont have to remove the spring just do this and to get it off the caliper pull away from the caliper and off the hook it attaches to on the caliper and route as necessary.
it is ok if it hits the frame, mine does and have had no problems and it still works great..
i did notice the e brake cable touches the rim in the drivers side so a hefty tie wrap took care of it..
jim
