One more plug to go !Any tips?
Come on, that's easier than the driver side rear... Swivel the fuel injector (gently) toward the front of the vehicle, pull it's molex plug off and put it aside. Remove the 7mm bolt from the spark-plug coil, pull the coil out first and then disconnect the plug's molex electrical connector, should remove easy after that. Now if you have swivel 3/8 extensions, should be easy, keep the extension shafts straight as possible, and the plug should unscrew with ease.
