Factory Tonneau Corners Lifting In Sun
Mine does the same thing.
I tried running a bungee cord across the back tiedowns, then hooking another bungee cord to each of the 'loops' then running them down to the one across the bed. . .worked for a while, then they started lifting again.
Poor design I think.
I hope someone has a solution.
What you need to do is take a utility knife and cut off the excess folds of vinyl from the underside of the corners. Be sure just to cut off the loose parts that are not sewn down. Don't cut anything past the stitching. It's hard to describe; but once you look at it, you'll see what I mean.
Thanks Edward!
