What Tire Pressure Would Be Best For My New Nitto 305/45/18 555R's On The Street?
I just ordered a set of Nitto 555R's 305/45/18 for the rear of my L and a set of Nitto 555's 295/45/18 for the front. I would like to know what air pressure should I run in the front and rear for daily driving and what I should drop the pressure to in the rear while at the track for the best traction and tire wear?
Thanks,
Thanks,
Hey Dude,
In the rear, I run 20-22 psi at the track. I run 28-30 psi on the street. If I know I'm going to do some street racing, I put them back to 22 psi. I would run 32 psi in the fronts.
They work pretty good on the street, just do a little burn out before you street race to heat them up.
I run about 27 psi. around town, Then If I'm going to go do some stomping around town and whoopin' some A$$ I run about 20 to 23 psi. Just don't take any corners fast or the tires will flex bad with low pressure in them and could pop off the rim or just lose control on corners. I've tried this already almost ended up in a ditch. But they hook awesome on the straight away!!!
Don't listen to DL HankFan...His truck is just PRETTY...LOL
j/k...DL
I was wondering what kind of 60's I could expect with nitto's...can only get 2.0's w/F-1's
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
NEXT:
Built Shortblock w/Ported Heads
Monster Box Tranny
JDM 166 Blower and 100mm MAF
AND DEFINITELY SOME BIGGER SLICKS
j/k...DL
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
JL 3# Lower Pulley
JDM Cold Air
JDM Boost Bypass
JDM Cobra R pump
JDM Eletric Fan
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
NEXT:
Monster Box Tranny
DL- Thanks for the info. After seeing those 555R's at WFC i just had to have a set. So I sold my ET streets and bought a set. Plus after hearing RobG getting 1.71 60 foot times I was sold. Oh and by the way where you stay at? LOL
RA6870- Thanks for the info. I will be sure to keep check on the tire pressure.
