5.4 Block ??
Old 06-08-2002 | 06:38 PM
DustOff49's Avatar
5.4 Block ??
Are all 5.4 Blocks created equal or are the 99-02 lightning Blocks different in anyway from a standard Ford 5.4 truck block ?
Thanks,
Jon L
Old 06-08-2002 | 07:24 PM
BlkBanshee's Avatar
Suspended Pending Email Reply
Lightning blocks are cast iron, vs aluminum in the non-s/c trucks.
Old 06-08-2002 | 09:40 PM
kdanner's Avatar
No, all 5.4 blocks are iron, including the 00 Cobra R.
Old 06-08-2002 | 10:28 PM
bob1999's Avatar
And folks, this is the exact reason that I consider this forum the tea sipping party of the Lightning sites. You simple can’t take anything serious here other than what car wax to use, hell even that will provoke a fight.
Never, never, believe anything technical that you read on this board! I fact half the post must be in jest, I suspect. There just can’t be this many L owner that can’t find the gas cap.
Entertaining in a bizarre way, yes; masochistic, yes!
Old 06-08-2002 | 10:57 PM
StruckBy99's Avatar
All 5.4's are iron.
What I think BlkBansee is refering to is the '03 Cobra compared to the other 4.6's. '03 Cobra 4.6 is iron, all other 4.6's are aluminim.
Jason
Old 06-08-2002 | 11:08 PM
Bad as L's Avatar
bob1999
I here that !!!!
I did something really dumb the other day, I did a search on this board, looking for a part # for a 2000 Lightning crankshaft. I found the number and went down to the dealership and ordered it. They sent me a V6 crankshaft.....I got some funny looks from the parts peaple for this.
The good thing is, that it was a second attempt....the first time the dealership didn't have any luck either.
Wich brings up another point, If anybody wants or needs a new lightning crank and you order one, Ford may send you a casting. Do NOT accept it. You need a forging and there is a huge difference in price. A real lightning crank list for almost 640.00 or at least mine did
Dale
Old 06-21-2002 | 08:32 PM
seabass55's Avatar
Originally posted by StruckBy99
All 5.4's are iron.
Jason
uhhh...2002 Explorer...4.6 aluminum block...previous Cobras 4.6...aluminum blocks. Not sure on the Marks but I think they are aluminum too...didn't someone above just talk about posting bad information? Atleast your right on the 03 Cobra.
Seabass
Old 06-21-2002 | 09:11 PM
BadBolt's Avatar
Man, my sip just went through my nose!
Old 06-22-2002 | 12:15 AM
StruckBy99's Avatar
seabass55
ALL 5.4's are IRON (Meaning that no 5.4's are Aluminum)
ALL 4.6's ARE aluminum EXCEPT for the 03 cobra, which is a 4.6 IRON block.
If you read what I originaly posted correctly, thats what I said.
geez man, 1st post and already talkin *****. WAY TO GO!
Hope this clears thing up,
Jason
Old 06-22-2002 | 12:25 AM
seabass55's Avatar
Now...since I did miss read your post...I'll correct myself...but yet...continue to flame you for passing bad information.....the 4.6's in both my blown 96 Bird and my 95 Cougar are Iron. So null the "all aluminum" comment. The original motor in the 96 had an iron block and the current motor out of a 99GT also has an iron block. So NO....not all 4.6s other than the 03 have aluminum blocks.
Sorry for misreading the origional post.
Seabass
Old 06-22-2002 | 12:48 AM
StruckBy99's Avatar
If you say that your 95 and 96 had an iron block, I believe you, BUT are you sure the 99's had an iron block?
From what I understand the 4.6's have been aluminum for quite some time, not too long after they started making the 4.6.
Just trying to get the facts straight, 'cause if you dont, someone is right there to tell you otherwise.
Jason
Old 06-22-2002 | 01:06 AM
kdanner's Avatar
Jason
Every 2V 4.6 has been iron with the exception of the 02 Explorer.
Every 4V 4.6 has been aluminum with the exception of the 03 Cobra.
Old 06-22-2002 | 10:15 AM
StruckBy99's Avatar
Thanks kdanner, Thats where I was confused.
Jason
Old 06-22-2002 | 10:25 AM
easterisland's Avatar
Re: 5.4 Block ??
Thanks,
Jon L
I believe the block was changed in 2001 and again in 2002. It is basically the same. I am installing a 99 block into my 2001.
Old 06-22-2002 | 11:14 AM
LightningTuner's Avatar
Whew!! This post went ALL sorts of out of whack
All 5.4 blocks are iron.
All 2V 4.6 blocks are iron, except for the new Explorer.
All Cobra 4.6 blocks are aluminum except for the 2000 R and the 03.
All 4V Mark 8 blocks are aluminum.
And getting back to the original question asked, the blocks are the same between the Lightning and the regular 5.4. All Triton truck 5.4s use the same crank, block, and rods, with the piston being the difference for lower compression on the Lightning. Ford changed the part number on the 01 blocks, I've heard some rumors that it had deeper cylinder skirts, but I have 99-00 and 01 blocks here and have not been able to measure or visually see a difference. Aside from that, Ford has replaced the 01 block part number with the previous 99-00 number.
Hope this helps.
Quick Reply: 5.4 Block ??
