billet accessories install help
The tilt lever is easy.It screws right off.There is a spot for a small wrench.
The Door lock pins will require you to take the door panel off.Not completely though.It is held on by 2 screws.One behind door handle(plastic piece just snaps off) and one behind the piece of plastic that goes up the door,above the panel(that also just snaps off).Un-screw(phillips head) both then lift the panel up and pull out a little,not too much.Then screw off lock pins,screw on new billet lock pins and put panel back on,screws back in and snap back on the handle piece and the upper piece.A lot easier then it sounds,unless it sounds easy.
Hope this helps.
VINNIE
Hope this helps.
VINNIE
