Changing T-Stat Question?
Re: Changing T-Stat Question?
Originally posted by Tim Cowley
I am changing my thermastat tommorrow with a Hypertech 160 degree . My question is as far as coolant-antifreeze should a fella mix water and coolant 50-50 or 100 percent. How much does it take and whats the best? Thanks for your help!
Tim:
If you get a small(?) vacuum hose about 2 feet long and squeeze it on to the nipple at the bottm, rt. corner of the radiator, you can drain 1 1/2-2 gals of coolant out and then reuse it. Just pour it back in the reservoir as the eng is idling after you're finished. I didn't spill nary a drop this way.
Dan
Dan
Re: Tim:
Dan
Dan
