Aluminum Pulleys ruin belts.....
Today I was told that aluminum pulleys will 'glaze' a belt. Apparently the aluminum wears onto the belt when the pulley gets hot and leaves a 'shiny' glaze on the belt which causes it to slip an ruins the belt.
Anyone ever had this happen?
is PSP's pulley aluminum?
JDM?
JL's?
THanks.
JDM?
JL's?
THanks.
what in the world did you do to that pulley?
I can't see that causing the belts to go bad cause allot of the big superchargers out there come stock with aluminum pulleys now.
I haven't had that trouble with my PSP or upper metco pulley .
If anything what we should do is get the pulleys media blasted so they grip better, thats what I want to do to mine next.
you win
Belt "glazing" is cause front extreme heat and friction....caused by slipping. This is what causes the "glazing". But.....consistant slipping with cause premature wear on an aluminum pulley and a steel pulley. A worn pulley will cause premature belt wear which leads to slipping and glazing. It's a vicious cycle!!!
Jay wins!!!!
Jay wins!!!!
SVTmoonshine,
Anodization is actually an Al oxide layer (which will occur naturally), but done in a controlled environment. Also, Al oxide is much harder than bare aluminum (its actually a saphyr crystal layer). So, the surface hardness can be determined by the anodizing process (how thick). Dyes can also be added during the process.
I'm not sure to what extent our tuners are anodizing thier pullies. But, like you, I suspect its mainly for aesthetics.
Any tuners want to respond?
-Kris
-Kris
